Quantumn
Apr 29, 2018Aspirant
Cascading Switches
 How is it, that I can connect a managed switch (GS105PE) into another managed switch (GS728-PE), and not be able to reach the first one?  But only when I plug another device into the first switch.
schumaku
May 01, 2018Guru - Experienced User
What kind of device is plugged there to the port - could this be something creating a network loop ie. over a concurrently active wireless connection? What I have in mind is (for example) a SONOS device.
Quantumn
May 01, 2018Aspirant
I've found that the reason this is happening is I was mirroring port 3 to port 5.  When I turned off mirroring this stopped.
But still, control of the switch through the web interface comes and goes.  More often than not when I try to change a setting, the page times out.  This happens whether the switch is powered from a PoE injector, or from my big switch.
