yvan-lab
Dec 01, 2023Aspirant
Change of subnet mask: system network protocol config mit ne NONE ?
Dear all, I have changed the subnet mask on the router from 255.255.255.0 to 255.255.252.0 because I need more addresses. This caused issues: the computers that were assigned one of the newly ava...
- Dec 01, 2023
Is the XS716T configured to Current Network Configuration Protocol for DHCP (Dynamic) probably? You need to configure it to a static IP to override the DHCP assigned Subnet Mask. Assuming your router is serving DHCP, and the DHCP server is correctly configured, you can consider to reboot the switch.
The settings are indeed on System - Management - IP Configuration
schumaku
Dec 01, 2023Guru - Experienced User
