yvan-lab
Dec 01, 2023Aspirant
Change of subnet mask: system network protocol config mit ne NONE ?
Dear all, I have changed the subnet mask on the router from 255.255.255.0 to 255.255.252.0 because I need more addresses. This caused issues: the computers that were assigned one of the newly ava...
- Dec 01, 2023
Is the XS716T configured to Current Network Configuration Protocol for DHCP (Dynamic) probably? You need to configure it to a static IP to override the DHCP assigned Subnet Mask. Assuming your router is serving DHCP, and the DHCP server is correctly configured, you can consider to reboot the switch.
The settings are indeed on System - Management - IP Configuration
schumaku
Dec 01, 2023Guru - Experienced User
yvan-lab wrote:
I rebooted the switch and the switch has set the correct configuration. Thank you very much.
It's in general much easier to deal with DHCP instead of fixing IP configs which can and will change on the next re-design.
yvan-lab wrote:
The WLAN still does not work, though. (I can connect to the router but not to the internet.) This might be a separate problem with the wlan access point... (It's an ASUS.)
A little bit vague what makes up the WLAN there for you. A wireless AP is typically a bridge connecting Ethernet and WiFi - for this purpose, an exact configuration might not be required. A little bit different of course when it comes to the AP management. What does provide the Internet on your installation? Any additional IP routing involved on the XS716T for example?
yvan-lab
A reboot of the AP and of the router solved the problem.
My router/model does not privide wifi. (Well, it does, but it's installed in the cellar, so I don't use that). I have wired ethernet throughout the house. The Uplink-AP is connected to the router by wire, and there are a few slave wifi APs that are connected to the Uplink-AP also through wire.
Thank you agein 🙂 I learned something.
