frdt
Jan 12, 2018Aspirant
Compatibility for AXM763 (10Gbic module)
Does this module AXM763 compatble with GS724Tv4 ? I want to link it with a M4300-28G ProSAFE 24-port 1G and 2-port 10GBASE-T and 2-port 10G SFP+ thx
- Jan 12, 2018
This is exactly right.
At least, one option still exists: the M4300-28G supports 1G speed on its 10G SFP+ interfaces, so it is possible to use AGM731F 1000BASE-SX transceiver (you indicated LRM mode so I am assuming multimode fiber) on both M4300-28G and GS724Tv4 for a 1Gbps full duplex interconnect.
schumaku
Jan 12, 2018Guru - Experienced User
frdt wrote:Does this module AXM763 compatble with GS724Tv4 ?
No. The AXM763 is a SFP+ 10GBASE-LRM Transceiver, while the GS724Tv4 does only have Gigabit SFP slots. SFP(+) interfaces as well as fibre Gbic don't have any speed negotiation capability.
frdt wrote:I want to link it with a M4300-28G ProSAFE 24-port 1G and 2-port 10GBASE-T and 2-port 10G SFP+
Even of we would assume there are counterparts on the other switch supporting the same speed, mixing different speed (1G and 10G) can't be used on a trunk, and mixed technologies (mixed latencies) in a trunk is a bad idea.
- LaurentMaJan 12, 2018NETGEAR Expert
