jreinauld
Feb 19, 2019Aspirant
compatibility with NETGEAR MS510TXPP
Hello all,
I have a Netgear MS510TXPP switch at work.
This switch has one "SFP+ fiber" port.
QUESTION 1:
Although it is presented as a "fiber" port, can anyone confirm that I can use ...
jreinauld
Hi Schumaku,
Thanks for your answer.
What I need to use is not a SFP+ <--> SFP+ cable like the one you suggest, but instead a QSFP+ <--> 4 x SFP+ adapter.
Is there any that is supported by the switch?
Thanks,
- Julien
schumaku
Feb 19, 2019Guru - Experienced User
I understand what you intend to do - however there is no such similar cable offered by Netgear, and nothing the like is certified therefore. It's a set-up which don't happen every day, so figure...
Worth a test. Well possible, it will work if this is a passive cable, permitting the other switch with the QSFP+ can run on a single 10G.
