ankitg
Feb 01, 2018Aspirant
Configuring Static IP on one interface and NAT it to internal VLAN
Hello! I am not very much familiar with Netgear managed switchs. What I would like to do is that I want to configure a static IP as an external IP 84.x.x.x on the router on any one interface and ...
JohnC_V
Feb 02, 2018NETGEAR Employee Retired
Hi ankitg,
Welcome to our community!
Your firewall / router should be the one handling the routing from your dhcp server to your external IP. You may try setting up protocol binding in your firewall and not the switch.
