ankitg
Feb 01, 2018Aspirant
Configuring Static IP on one interface and NAT it to internal VLAN
Hello! I am not very much familiar with Netgear managed switchs. What I would like to do is that I want to configure a static IP as an external IP 84.x.x.x on the router on any one interface and ...
JohnC_V
Feb 05, 2018NETGEAR Employee Retired
I would like to have a follow up on this thread. Please let us know if everything works ok now or you still need further assistance.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
ankitg
Feb 06, 2018Aspirant
Hello!
I actually did not get what I was looking for but it seems that I am looking at wrong product type for the functionality which I want i.e. I realised now that it is only a managed switch and it cannot bind to a static address on any interface and route the traffic between VLAN.
I think I need a router for the functionality I am looking for.
I agree to close this thread.
Thanks for your reponse and help.
Ankit G
- schumakuFeb 06, 2018Guru - Experienced User
Of couse these swiches can act as a L3 routers, routing between different IP subnetworks on the different VLANs. There is "just" no NAT capability - as this has no real usage in business networking on this device class. The addresses are bound to the VLAN, not to ports of course.
