H3LD3R's avatar
H3LD3R
Connect 2 gs324T switches with 2 vlans both together.
So here is my problem.
I have two GS324T switches and i have made two vlans on each switch both the same.
1t/m12 + 25&26 are my LAN ports and 13t/m 24 are my WAN ports.
The software version is 1.0.0.17
When i connect both switches in the lan vlan then i can see everything that i have in both switches.
But when i put in my Internet line in one of the switches in my WAN vlan then i dont have internet.
When i pull the cable out of the lan vlan i do have internet connection on both.
Has someone had the same issue?
  • schumaku's avatar
    schumaku
    Based on the information supplied, I'm a little bit lost what makes up the two VLAN, what IP subnets are intended, and how the VLANs with multiple ports are interconnected.
    • H3LD3R's avatar
      H3LD3R
      I understand! Thanks for replying. I have made a small drawing so i hope this makes it more clear.
      What i wanted to create were just simple two vlan's that act like seperate switches inside the 324.
      But im not a network professional and i have had struggles with this!
      • schumaku's avatar
        schumaku
        Still unclear about the 1t/m12 13t/m24 notation.
        To establish a VLAN 1 resp. a VLAN 13 "LAN" connection, the ports need to be untagged to the respective VLAN ID and the PVID must be set accordingly, too.
ProSupport for Business
