NGSC101Usr's avatar
NGSC101Usr
Detected port speed
H All,
Can anyone help with the following...
I have a HDBASET device connected to this switch and it operates at GB speed as per vendor, passing audio/video, full HD and 4k/2k. Despite this, the switch detects it at 100MB rather than setting port speed to 1GB. My question(s) are:
1. Is it possible to override "Auto" setting to "hard set" speed to 1GB, which is not an available setting on switch?
2. When using the VPN feature, what are the optimal settings for audio/video, including settings for broadcast QOS, rate limits, etc.?
Thanks in advance.
  • JohnRo's avatar
    JohnRo
    May 20, 2016
    Hello NGSC101Usr,
    Yes, that is true however this switch it has some limitation compared to the Layer 2+ and Layer 3 models. By default, it is set to Auto for 1GB and all other options are only for lower speeds. I believe this is by design. It can be used on a VPN network, yes. On its own it does NOT have a VPN capability, remember that this is only a ProSafe Plus switch and not a firewall/router.
    Thanks,
  • JohnRo's avatar
    JohnRo
    NETGEAR Employee Retired
    Hello NGSC101Usr,
    Welcome to the community!
    What is the model number of your device? I only see GS108PEv3 entered on the model number line. If so, there is no option to have it on 1GB since it is auto sensing. It detects the speed of the devices that you plug into it. The GS108PEv3 does not have a VPN feature, so please tell me if this is not the correct model.
    Thanks,
    • NGSC101Usr's avatar
      NGSC101Usr
      Hi JohnRo,
      Thanks for the reply.
      The model number is as previously specified, I'm not aware of any other designation. This model does have VPN ability as I have this set up now, which is why I enquired about broadcast settings, amongst other things.
      Presumably, from what you said, I cannot "hard set" a 1GB setting. Why are there manual settings for all other speeds apart from the 1GB speed?
      Thanks.
      • JohnRo's avatar
        JohnRo
        Hello NGSC101Usr,
        Thanks,
ProSupport for Business
