cigb's avatar
cigb
Device view Java plugin not working
Currently I have installed two netgear managed switches: M5300-52G3 and GSM7248V2. I can't see the switch diagram in the Device view page. It reads "You need the Java Plugin. Get it from here" but "h...
  • JennC's avatar
    JennC
    Dec 31, 2015
    Hello anha,
    You can try using a different computer that has not updated Java as a work around. We are still waiting for a fix and might take months.
    Or try the following:
    -Uninstall java 8
    -Manually install java 7
ProSupport for Business
