cigb
Dec 03, 2015Aspirant
Device view Java plugin not working
Currently I have installed two netgear managed switches: M5300-52G3 and GSM7248V2. I can't see the switch diagram in the Device view page. It reads "You need the Java Plugin. Get it from here" but "h...
- Dec 31, 2015
Hello anha,
You can try using a different computer that has not updated Java as a work around. We are still waiting for a fix and might take months.Or try the following:-Uninstall java 8-Manually install java 7Regards,
scott_2015
Dec 16, 2015Aspirant
I have the same issue with all of our Netgear switches. Unable to use Device View because of Java error. Tied all the suggestions posted in this thread.
DaneA
Dec 17, 2015NETGEAR Employee Retired
Hi scott_2015,
Welcome to the community! :)
A few questions below:
a. Have you tried using other PC/s or laptop/s to further isolate the problem?
b. What specific NETGEAR switches do you have wherein you are unable to use Device View?
c. What is the current firmware versions of the NETGEAR switches wherein you are unable to use Device View?
I look forward to your response.
DaneA
NETGEAR Community Team
