cigb
Dec 03, 2015Aspirant
Device view Java plugin not working
Currently I have installed two netgear managed switches: M5300-52G3 and GSM7248V2. I can't see the switch diagram in the Device view page. It reads "You need the Java Plugin. Get it from here" but "h...
- Dec 31, 2015
Hello anha,
You can try using a different computer that has not updated Java as a work around. We are still waiting for a fix and might take months.Or try the following:-Uninstall java 8-Manually install java 7Regards,
anha
Dec 30, 2015Aspirant
Same problem here. Running Java 8, update 66. Error appears in Internet Explorer, Chrome and Firefox on Windows 8.1 on several pc systems. Switch (4100-26G, firmware version 10.0.2.13) has had several factory resets without any result. The error:
| Device View |
| !-- --------------- --> You need the Java Plugin. Get it from here. |
Unfortunately the link is not pointing tot a java version capable of running the app.
JennC
Dec 31, 2015NETGEAR Employee Retired
Hello anha,
-Uninstall java 8
- DydgeJan 02, 2016Initiate
Install Java 7.... it's realy absurd for the safety of our PC !!!
Netgear, Fix it quickly !!
- ohio_capsJan 25, 2016Aspirant
I agree, I have the same problm. Java 7 support ended April 2015. No security updates to one of the most exploited codes on planet earth is not a good answer.
