cigb
Dec 03, 2015Aspirant
Device view Java plugin not working
Currently I have installed two netgear managed switches: M5300-52G3 and GSM7248V2. I can't see the switch diagram in the Device view page. It reads "You need the Java Plugin. Get it from here" but "h...
- Dec 31, 2015
Hello anha,
You can try using a different computer that has not updated Java as a work around. We are still waiting for a fix and might take months.Or try the following:-Uninstall java 8-Manually install java 7Regards,
JennC
Dec 31, 2015NETGEAR Employee Retired
Hello anha,
-Uninstall java 8
Dydge
Jan 02, 2016Initiate
Install Java 7.... it's realy absurd for the safety of our PC !!!
Netgear, Fix it quickly !!
- ohio_capsJan 25, 2016Aspirant
I agree, I have the same problm. Java 7 support ended April 2015. No security updates to one of the most exploited codes on planet earth is not a good answer.
