Ben_Gib
Apr 25, 2019Aspirant
Devices with static IP's
Hi everyone,
We have two industrial PLC's (PLC = these boxes in CNC maschines and the like) with static IP addresses which must communicate with a virtual maschine where the database is located.
- May 01, 2019
Nothing wrong with the home router approach, isn't it? Except that it might have some (forced) NAT on.
Any Netgear L2+ or L3 switch (mandatory feature: IPv4 routing) from the Smart Managed Pro or Managed switch class configured with two VLANs and a proper routing config for the two subnets will do the job. To my knowledge, Netgear does not offer "generic" routers.
At the end of the day it depends on exactly your lab has match the customer environment.
PS: Well, consider a heavy iron (not consumer or SMB) router it will be some 5000 bucks plus 15% maintenance and support p.a., there can't be anything wrong, and nobody was fired because of buying C***** 8-)
Ben_Gib
May 01, 2019Aspirant
Hi
Let me thank you for your answer. A bit late, sorry.
In regard to your first solution, I would be in favour of the L3 router, but really unsure which model I should buy. If I say to the boss :"model xy will work, it's just 500$" and then it does not work .... well I only work 3 weeks there and intend to stay longer employed.
Your second solution was new to me, well I knew it once 20 years ago, thanks for refreshing my memory. Unfortunately, the IP addresses are absolutely fixed.
I worked around with an old Internet router. The database is connected on the WAN Port and the PLC's are on the router's LAN. It works.
If anybody can give me a recommendation for a simple L3 Netgear router which can handle this scenario, I would be open to hear that. I mean, this Home router setup is a bit lame.
Thanks
schumaku
May 01, 2019Guru - Experienced User
- Ben_GibMay 02, 2019Aspirant
I thank you with three virtual foot kisses for this information! :smileyhappy:
The C**** is not an option, the company owner says that all network devices must be from the same manufacturer. It makes some sense, then on the other hand not really much, think NIC's. But it is surely a plus because the web interfaces of the network gear looks always familiar.
