Liander's avatar
Liander
Guide
Oct 03, 2017
DHCP configuration on MX4300-48X
Hello Everyone, I've got one configuration Issue: I'm new to the M4300 ProSAFE Switch and I'm trying to configure it. I've noticed that there is a DHCP server section under System -> Services and I ...
  • JohnC_V's avatar
    JohnC_V
    Oct 11, 2017
    Liander,
    You are correct. Actually the last article that I just shared with you was the DHCP configuration on that, not the whole routing. You don't need to enable VLAN routing anymore on this setup as it will be handled already by your external router. So no need to worry about that. My apologies with the confusion.
ProSupport for Business
