Liander
Oct 03, 2017Guide
DHCP configuration on MX4300-48X
Hello Everyone, I've got one configuration Issue: I'm new to the M4300 ProSAFE Switch and I'm trying to configure it. I've noticed that there is a DHCP server section under System -> Services and I ...
- Oct 11, 2017
You are correct. Actually the last article that I just shared with you was the DHCP configuration on that, not the whole routing. You don't need to enable VLAN routing anymore on this setup as it will be handled already by your external router. So no need to worry about that. My apologies with the confusion.
JohnC_V
Oct 10, 2017NETGEAR Employee Retired
To associate a DHCP pool to a VLAN, ensure that the network address of the pool matches the network address of the VLAN. For example, VLAN 10 in this example is assigned the IP address 192.168.10.254 and network mask 255.255.255.0. This has a network address of 192.168.10.0. When creating the DHCP pool for VLAN 10, ensure that the network address is 192.168.10.0 with network mask 255.255.255.0. The switch automatically assigns the DHCP pool to the corresponding VLAN (VLAN 10 in this case).
Please refer on this article.
Liander
Oct 10, 2017Guide
Thank you again, one last question about this: I don't want to use routing capablities of the switch, instead I've got an external router. To assign an IP to a vlan is correct to use the menu Routing -> VLAN -> VLAN Routing configuration?
In my example Vlan 400 is a 172.24.123.0/24 and Vlan 4 is a 172.24.32.0/23 so my VLAN Configuration is this:Then I've configured a DHCP Pool only for 172.24.123.0/24 like this:
Obviusly Routing doesn't have to work. Routing must be handled by my external router: is enough to disable it from the menu Routing ->IP -> Ip Configuration?
Excuse me but before putting al settings online I've got to be sure about configuration because this is an important core switch.
Thanks again
Luca
