Alain_Sanchez
Feb 13, 2023Aspirant
Disable in-band management on M4300-28G
I want to disable any in-band management possibility on my M4300-28G and leave only OOB management. Currently I'm using the switch as a router and set the management vlan to 999 which is a vlan that...
schumaku
Feb 14, 2023Guru - Experienced User
This is the intended default behavior for the in-band management..
The in-band CPU management access can be disabled, limiting the access to the the switch CPU for GUI, telnet etc. via the OOB service port if you have a separate management network. Further on you can deploy Management ACLs for protecting inband access (for instance, restricting HTTP GUI access to certain IP addresses or subnets, restricting Telnet to certain other IP addresses, etc.).
- Alain_SanchezFeb 14, 2023Aspirant
How can I disable in-band CPU management access? I have Management Source Interface set to Service Port yet I still have in-band access to management.
Also, I don't understand why I can access switch management from every single vlan of the switch with an IP address if I explicitly selected a Managenment VLAN. What's the point of having an in-band management vlan if I can access the switch from every vlan with routing enabled?
- schumakuFeb 14, 2023Guru - Experienced User
These are no consumer class devices with simple on-off controls for many reasons.
Well, you have enabled OOB, this does not imply any in-band vectors will be disabled.
A kind of an industry standard on business switches and routers.
In-band and out-of-band is fully concurrent.
Put up access controls for all vectors you want to allow or deny.
- LaurentMaFeb 14, 2023NETGEAR Expert
HI Alain_Sanchez ,
You should restrict Management Access using Access Control.
https://www.netgear.com/support/product/M4300.aspx#docs
- for instance the Web GUI User Manual https://www.downloads.netgear.com/files/GDC/M4300/M4300_M4300-96X_UM_EN.pdf
starting page 544.
This way, any unapproved origin IP/service will be discarded by the CPU (we call it Management CPU ACL)
I hope it will help you,
Laurent Masia
