Alain_Sanchez
Feb 13, 2023Aspirant
Disable in-band management on M4300-28G
I want to disable any in-band management possibility on my M4300-28G and leave only OOB management. Currently I'm using the switch as a router and set the management vlan to 999 which is a vlan that...
schumaku
Feb 14, 2023Guru - Experienced User
Alain_Sanchez wrote:
Ok, I'm now filtering access to management services using Management ACLs but I still see some webservice listening on tcp/8443, and I can't find out how to disable it.
The M4300 series switch does host the REST API service using the https protocol on port 8443 afaik.
I changed SSH service to port 2200 and activated my Access Profile, then ran an Nmap scan from Internet and it shows port 22 being explicitly filtered but not the new port SSH is listening (2200). Any suggestion?
Port 22 shows as explicitly filtered because it is eg. remapped internally.
Seriously have ports like 2200/tcp mapped and suspect open to the wild Internet?
LaurentMa
Feb 14, 2023NETGEAR Expert
Hi Team, if you don't want to see the TCP ports opened any more (Rest API and AV UI) please stop the applications and un-install them. You can re-install them later in the CLI if needed.
User:admin
Password:********
(M4300-28G) >enable
(M4300-28G) #show application
OpEN application table contains 3 entries.
Name StartOnBoot AutoRestart CPU Sharing Max Memory Preload Version
AVUI Yes Yes 0 0 Yes 2.2.3.11
RestAgent Yes Yes 0 0 Yes 2.0.1.32
discAgent Yes Yes 0 0 Yes 1.0.0.3
(M4300-28G) #application stop AVUI
Application stopped.
(M4300-28G) #application stop RestAgent
(M4300-28G) #config
(M4300-28G) (Config)#no application install AVUI
(M4300-28G) (Config)#no application install RestAgent
(M4300-28G) (Config)#exit
(M4300-28G) #save
- Alain_SanchezFeb 14, 2023Aspirant
Firmware version is 12.0.15.7. Can't see AVUI, RestAgent application but switch still listening on tcp/8443.
