Alain_Sanchez
Feb 13, 2023Aspirant
Disable in-band management on M4300-28G
I want to disable any in-band management possibility on my M4300-28G and leave only OOB management. Currently I'm using the switch as a router and set the management vlan to 999 which is a vlan that...
LaurentMa
Feb 14, 2023NETGEAR Expert
Hi Team, if you don't want to see the TCP ports opened any more (Rest API and AV UI) please stop the applications and un-install them. You can re-install them later in the CLI if needed.
User:admin
Password:********
(M4300-28G) >enable
(M4300-28G) #show application
OpEN application table contains 3 entries.
Name StartOnBoot AutoRestart CPU Sharing Max Memory Preload Version
AVUI Yes Yes 0 0 Yes 2.2.3.11
RestAgent Yes Yes 0 0 Yes 2.0.1.32
discAgent Yes Yes 0 0 Yes 1.0.0.3
(M4300-28G) #application stop AVUI
Application stopped.
(M4300-28G) #application stop RestAgent
(M4300-28G) #config
(M4300-28G) (Config)#no application install AVUI
(M4300-28G) (Config)#no application install RestAgent
(M4300-28G) (Config)#exit
(M4300-28G) #save
Alain_Sanchez
Feb 14, 2023Aspirant
Firmware version is 12.0.15.7. Can't see AVUI, RestAgent application but switch still listening on tcp/8443.
