GregAdno
Sep 30, 2024Aspirant
Disableing RSTP on specific ports GS308T
Hi I have a situation where I need to disable RSTP on 2 ports on my GS308T switch, as these ports directly connect to devices which do not support RSTP, unfortunately I cannot seem to find a way to m...
Sep 30, 2024Guru - Experienced User
Only see this mentioned for full managed switches:
I don't see this model being included.
Might check the user manual to see if there is any user configurations for RSTP for this model switch.
- GregAdnoSep 30, 2024Aspirant
Hi it does have RSTP configuration options but it sems l;ike the RSTP is global, while some of the other Spanning Tree protocols also have port specific options??
i
