GregAdno
Sep 30, 2024Aspirant
Disableing RSTP on specific ports GS308T
Hi I have a situation where I need to disable RSTP on 2 ports on my GS308T switch, as these ports directly connect to devices which do not support RSTP, unfortunately I cannot seem to find a way to m...
Sep 30, 2024Guru - Experienced User
Only see this mentioned for full managed switches:
I don't see this model being included.
Might check the user manual to see if there is any user configurations for RSTP for this model switch.
GregAdno
Hi it does have RSTP configuration options but it sems l;ike the RSTP is global, while some of the other Spanning Tree protocols also have port specific options??
i
