VincentKhoo
Jan 09, 2019Aspirant
Does Netgear managed switch support putty ssh with auto command file
Hi,
i am running a system to have different bat file command to run putty with ssh, example like : putty.exe -ssh user@switch-ip -pw password -m C:\temp\commands.txt, the purpose is that I need...
JohnC_V
Jan 10, 2019NETGEAR Employee Retired
Hi VincentKhoo,
Welcome to our community! :)
I did inquire your case and as per our engineering team, this function is not supported in our switches.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
