VincentKhoo
Jan 09, 2019Aspirant
Does Netgear managed switch support putty ssh with auto command file
Hi,
i am running a system to have different bat file command to run putty with ssh, example like : putty.exe -ssh user@switch-ip -pw password -m C:\temp\commands.txt, the purpose is that I need...
JohnC_V
Jan 14, 2019NETGEAR Employee Retired
I would like to have a follow up on the thread that you posted. Please let us know if everything is ok now or you still need further assistance.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
