ChoiMJ
May 09, 2018Follower
Down from 1 Gbps to 100 Mbps
I am using GS108E v3 "Linked Speed" changes in a few hours. Can not set 1Gbps?
Firmware Version
V2.06.03EN
* Client Setting
Retired_Member
May 09, 2018Hi ChoiMJ,
Welcome to the community!
Could you please set both switch port and PC port to auto-negotiate mode, and try again? I think the port will up at high-support speed(in your case, it should be 1Gbps).
Hope it helps!
EricZ
NETGEAR employee
