themurf47
Feb 23, 2022Aspirant
Factory Reset button location M4250
I have started using the M4250 series ov A/V switches. I have one that is not behaving as expected and after considerable time with tech support it was decided to performa factory reset. I could not ...
Mar 05, 2022Guru - Experienced User
Any progress on this?
themurf47 wrote:
I have started using the M4250 series ov A/V switches. I have one that is not behaving as expected and after considerable time with tech support it was decided to performa factory reset. I could not stay on the phone with the tech for the procedure. When I got back to the project I can't, for the life of me, find a reset button on the device anywhere. The manual only gives a reset procedure if you can log into the device which I can't since that is the problem. I have looked for a picture of the device where it shows the lights and connections with descriptions but can't find that either. Anyone here know where I need to look? Thanks in advance.
