chrisg_bandd
Feb 09, 2015Aspirant
Fiber optic or LAG or both
We have a network of 15-20 PCs in a network the transfers large CAD file frequently (upwards of .5 Gb) We occasionally have considerable lags in loading and saving files. We are buying a new server a...
Nhellie
Feb 10, 2015Virtuoso
I believe the GSM series should fit the requirements. You'll just have to consider how much latency are you getting to decide whether you need LAG or not.
