viknesh's avatar
viknesh
Fiber patch cords for M4300-24x24F
am laying OS2 singlemode fiber cable at distance around 1000 meters to connect interbuilding. Fiber will be connected direct to SPF+ to SFP+ transreceiver ) without using closet housing. I am using M4300-24X24F at both ends. What will be the best fiber connectors suitable to use? LC duplex or ? at the transreceiver?
  • Hi viknesh
    Welcome to the Community!
    This is great to see you selected our excellent M4300-24X24F 10G hybrid (copper/fiber) aggregation switch here.
    With your singlemode mode “OS2” fiber interconnect, please use AXM764 10GBASE-LR LITE SFP+ transceiver on both ends. It will drive 10 Gigabit Ethernet up to 2 km (1.243 miles) distances with legacy 9/125µm singlemode fiber cables. It is more cost effective than 10GBASE-LR (AXM762) able to reach 10 kilometers instead.
    Yes, AXM764 transceiver requires LC duplex connector.
    I hope this helps!
  • LaurentMa's avatar
    LaurentMa
    NETGEAR Expert
    Hi viknesh
    I hope this helps!
    • viknesh's avatar
      viknesh
      Thanks for the reply. I will looking forward to get 2 units of M4300 24x24F, 2 units 12x12F and 20 units of 8x8F and all will be using AXM764  at all switches to interconnect the switches between 12-14 building.
      Thank you for the timely reply and solution.
        LaurentMa
        NETGEAR Expert
        Hi viknesh
        Thank you for letting the Community know!
        Please come back and update us afterwards, it will be great to learn how went your deployment, how is the performance, etc.
ProSupport for Business
