advantagecom
Mar 25, 2009Novice
Firmware 7.3.1.7
Has anyone running a GSM or FSM series L3 managed switch tried firmware 7.3.1.7? I'm really curious about stability of this new release. 7.1.1.7 and 7.2.1.6 were not very stable (IP routing, VLAN, ...
advantagecom
Jul 14, 2010Novice
alex74 wrote: Hi,
Is it worth upgrading to 8.* version from 7.1.1.7 ? Is it much more stable than 7.1 ?
Thanks,
In our experience, the entire 7.x.x.x line of firmwares is buggy and unstable. 7.1.1.7 is even worse than 7.3.1.7. We had massive problems with STP and L3 routing with the 7.x.x.x firmwares. Furthermore, the 7.x.x.x firmwares are vulnerable to multiple remote DOS attacks that leave you with a hard-locked switch that requires a power cycle to get it going again.
Yes, it is definitely worth the upgrade. Just make sure you follow the instructions Netgear supplies.
