suraj_s
Nov 18, 2021Aspirant
firmware update 2.0.3.2 to 2.0.6.3
I have GS724TPv2 GE Managable switch with me. The current running firmware on it is 2.0.3.2 and I want to update it to 2.0.6.3(latest available version).
Can I directly update from 2.0.3.2 to 2.0.6.3, or I need to do all the previous versions step by step like: 2.0.3.2 > 2.0.4.2 > 2.0.4.3 > 2.0.6.1 > 2.0.6.3
- JeraldMNETGEAR Employee Retired
- suraj_sAspirant
So I can directly upgrade the firmware isn't it?
In instructions I found that the HTTPS will get disabled after the update, currently when I am trying to access the via IP only, it is redirecting to HTTPS, so I hope after upgrading, it wont happen.
Yes, you can directly upgrade it.
When it comes to accessing the admin page of the switch, you can explicitly type in http://IP_address_of_switch if typing just the IP address won't work.
You can check page 262 of the user manual here if you'd like to re-enable HTTPs access.
