Alexander_v_W
Mar 02, 2020Aspirant
Firmware Update how to
Hi there, how can i update the firmware of the XS712Tv2? I did not find any solution in the documenation nor anywhere else. The switches have software version 6.6.3.5 and i wanted to update to t...
- Mar 02, 2020
Thank you for your message
You can find XS712Tv2 documentation on its support page:
https://www.netgear.com/support/product/XS712Tv2#docs
More specifically you can use the User Manual page 398:
http://www.downloads.netgear.com/files/GDC/XS708T/XS708T_XS716T_UM_EN.pdf
Section is called <<Download a file to the switch or update the software using HTTP >>
Before that, you can download latest XS712Tv2 firmware 7.0.0.20 from the XS712Tv2 support page :
https://www.netgear.com/support/product/XS712Tv2#download
Firmware and Software Downloads
I hope it will help you,
Regards
LaurentMa
Mar 02, 2020NETGEAR Expert
Regards
- schumakuMar 02, 2020Guru - Experienced User
Merci Laurent!
There is even more information in the (as of writing) current firmware release notes https://kb.netgear.com/000061325/XS708T-XS712Tv2-XS716T-Firmware-Version-7-0-0-20 - appears that certain firmware versions are required for "any" update, e.g. by using the Web UI - otherwise the utility needs to be used.
- Alexander_v_WMar 02, 2020Aspirant
Hi Laurent,
thanks a lot for you help. I was a little bit confused about the expression "software", because i was looking for "firmware".
Another thing came up. In the documentation you can read, do not update your current image, otherwise an error will come up. I did read this afterwards, my fault, but no error showed up. So, can i use this updated "image1" or should i have to overwrite it, with the one i copied before the update to "image2".
And another question. Will the configuration also be saved, if i clone the actual "image1" to "image2"?
Many thanks for help and i really aoppreceate your quick response
Alexander
- schumakuMar 02, 2020Guru - Experienced UserAlexander,
Firmware and software (utilities for example) are hosted in the same download section. Hope you have not missed to unpack the ZIP archive before uploading - the switch can't handle this. Probably there are some things misleading in the Web UI ref. Upload and Download - and the selection of what you intend to upload.
It's a good policy to upload the new firmware into the inactive partition - this will keep the current running in case of an issue. In the Web based uploader you can select the destination. In case of replacing the active image, the other might become highly outdated. Not aware that replacing the active image should lead to an upload error - no idea from where this information should come from.
The config is independent of the firmware image selection.
-Kurt
