Alexander_v_W
Mar 02, 2020Aspirant
Firmware Update how to
Hi there, how can i update the firmware of the XS712Tv2? I did not find any solution in the documenation nor anywhere else. The switches have software version 6.6.3.5 and i wanted to update to t...
- Mar 02, 2020
Thank you for your message
You can find XS712Tv2 documentation on its support page:
https://www.netgear.com/support/product/XS712Tv2#docs
More specifically you can use the User Manual page 398:
http://www.downloads.netgear.com/files/GDC/XS708T/XS708T_XS716T_UM_EN.pdf
Section is called <<Download a file to the switch or update the software using HTTP >>
Before that, you can download latest XS712Tv2 firmware 7.0.0.20 from the XS712Tv2 support page :
https://www.netgear.com/support/product/XS712Tv2#download
Firmware and Software Downloads
I hope it will help you,
Regards
LaurentMa
Mar 02, 2020NETGEAR Expert
Regards
schumaku
Mar 02, 2020Guru - Experienced User
Merci Laurent!
There is even more information in the (as of writing) current firmware release notes https://kb.netgear.com/000061325/XS708T-XS712Tv2-XS716T-Firmware-Version-7-0-0-20 - appears that certain firmware versions are required for "any" update, e.g. by using the Web UI - otherwise the utility needs to be used.
