lambertsonm
Jul 17, 2019Guide
Firmware Update
Hi everyone, I just want to make sure I do this correctly. I currently have firmware version 11.0.0.12 and want to upgrade to version 11.0.0.31. As I go through the directions it says to go to the ...
- Jul 17, 2019
Hi,
Afraid, I must agree the guidelines, and especially the screenshots in the newer release notes (like M5300 Firmware Version 11.0.0.28) are unclear and misleading - including v12 references in the screenshots.
You can continue using the way the firmware image (nickname: Archive) was uploaded on earlier firmware versions with the "old" Web UI design - head to Maintenance -> Download -> HTTP File Download (one of my few complaints on the Netgear switches - complete academic view of upload vs. download, very unique in the industry, the UI designer was certainly a Doctor Professor for Physics) and select Archive and the image storage location (image 1 or image 2). Cross check with the legacy UI update process, e.g. M5300 Firmware Version 10.0.0.53 as a reference.
LaurentMa - food for thought, thank you!
-Kurt
lambertsonm
Jul 19, 2019Guide
Just so everyone knows. Even after the upgrade to firmware version 11.0.0.31 the instructions are still wrong in the same areas I mentioned in the original question post. So the directions on version 11.0.0.28 and 11.0.0.31 are not correct. Hope this post helps otheres.
