zwartemerel
Dec 28, 2015Aspirant
FS726TP - vlan cannot acces other device
Situation FS726TP switch setup 2x vlan Vlan1 - untagged - ports 1-8 / 13-24 Vlan2 - untagged - ports 9-12 Vlan1 - windows server dhcp - 192.168.10.x range Vlan2 - draytek2920 port4 dhcp ro...
DaneA
Dec 28, 2015NETGEAR Employee Retired
Hi zwartemerel,
Welcome to the community! :)
Here are my questions below:
a. If you connect the device/s (NAS, IP camera, etc.) directly to a PC, are you able to access the web interface of the device/s?
b. What is the current firmware version of the FS726TP?
c. What is the Operating System of the computer you are using to access the web interface of the device/s? Is it Windows 10/8//7/Vista/XP or MAC?
d. Have you check the IP setting (such as DNS, default gateway) of the device/s you want to access the web interface?
I look forward to your response.
DaneA
NETGEAR Community Team
zwartemerel
Jan 05, 2016Aspirant
Hello,
after some experience, i find out the connection to the other devices gives the problems,
a other switch in the network gives the troubles.
its all fine now ;-)
Henri
- DaneAJan 05, 2016NETGEAR Employee Retired
Hi zwartemerel,
I am glad to know that everything is fine now. :)
Feel free to post your future concerns here in the community.
Cheers,
DaneA
