AzurBlock's avatar
AzurBlock
NetGear FS726TP VLAN Creation / Tagging-Untagging ports
Hi everyone.
I am having troubles changing configuration of ports on my FS726TP.
In the documentation it says that clicking under Port Number should change the Port from Tagged to Untagged.
By default, all ports are untagged and clicking it changes nothing.
I am trying to figure this out because I need to create 2 separate VLANs which I am also having troubles with because changing any VLAN configuration is impossible for me.
Switch firmware is : 2.0.1_09_E
Thank you in advance,
Azur
  • AzurBlock,
    Welcome to the community!
    Just to clarify, the box doesn't change from Blank to Untagged or Tagged whenever you click it?
    If so, please check if you tried the following:
    • Tried different browsers
    • Tried configuring it on VLAN1 and see if it's the same behavior
    • Updating the switch to the latest firmware
    JeraldM
    NETGEAR Community Team
  • JeraldM's avatar
    JeraldM
    NETGEAR Employee Retired
    AzurBlock,
    JeraldM
    • AzurBlock's avatar
      AzurBlock
      Sorry for the late reply.
      Turns out Safari is not very friendly 🙂
      Thank you very much,
      Kudos to you.
      Best regards,
      Azur
