gbrown1001
Nov 02, 2011Aspirant
FSM 7328S Not Responsive on LAN Ports
Hi, Got an ebay purchase here sold as working but I have no experience of these products. Basically I don't see a connection light if I plug in a LAN cable. I have just rebooted the switch and plug...
jmizoguchi
Nov 02, 2011Virtuoso
ftp://downloads.netgear.com/files/7300_CLI.pdf
have you see this pdf?
I think one of your issues is even you get login prompt , your admin account will be hard to reset for password because you have to get login first.
I had bought some terminal server rack and I could not clear it. you almost have to to do some jtag to reflash the firmware to fix the problem is one way. I end up bought new one instead to since this old terminal server I got from ebay and I had to tinker with special IC chip I need to work with.
