gbrown1001
Nov 02, 2011Aspirant
FSM 7328S Not Responsive on LAN Ports
Hi, Got an ebay purchase here sold as working but I have no experience of these products. Basically I don't see a connection light if I plug in a LAN cable. I have just rebooted the switch and plug...
gbrown1001
When I use the ? in the console all I get is:
devshell Execute devShell command. Only admin user can run this
command.
So I guess whatever mode I am in this is the only command. I think I need to try to flash it! In the Utility menu I can see the "Load Stack Code Update Package using XMODEM/YMODEM/ZMODEM" Can I use that?
Thanks
Graham
command.
Thanks
Graham
