gbrown1001
Nov 02, 2011Aspirant
FSM 7328S Not Responsive on LAN Ports
Hi, Got an ebay purchase here sold as working but I have no experience of these products. Basically I don't see a connection light if I plug in a LAN cable. I have just rebooted the switch and plug...
gbrown1001
Well I downloaded a copy of 6.2.0.14 and have started to flash the unit via XMODEM. Now I have just found this advice below:
http://support.netgear.com/app/answers/detail/a_id/22/~/what-to-do-when-my-managed-switch-does-not-boot-up%3F
For GSM73xxS, instead of using the firmware images available on the NETGEAR support site, first obtain the file “gsm73xs-6.2.0.6.opr” available from URL ftp://downloads.netgear.com/files/gsm73xxs-6.2.0.6.opr. Then, use the following procedure to load the switch with that file. After reboot the switch, upgrade to the 6.3.x.x firmware normally using either TFTP or HTTP from WEB interface, or copy command from CLI. The file “gsm73xxs-6.2.0.6.opr” should only be used for loading the switch using XMODEM and serial console. Do NOT use the file for normal firmware upgrade using TFTP.
Do you think I should allow it to finish and go through with the operation by storing the code to flash using the firmware I chose or tell it not to save the file and re-upload the .opr file instead?
