gbrown1001
Nov 02, 2011Aspirant
FSM 7328S Not Responsive on LAN Ports
Hi, Got an ebay purchase here sold as working but I have no experience of these products. Basically I don't see a connection light if I plug in a LAN cable. I have just rebooted the switch and plug...
gbrown1001
Nov 03, 2011Aspirant
Well I re-flashed and after it completed I quit the utilities. I got a login prompt but username of admin and blank password did not work. I figured I should reboot it.
After the reboot I am back to the usual Unit 1> then changing to Unit 4> when I press any key.
Will NetGear help me on this if I raise a ticket? I'm sure this is just a case of resetting to default and all should work, it just looks like it is configured as a stack slave.
Thanks
Graham
Thanks
Graham
