marioalpha
Nov 20, 2015Aspirant
FSM726 V2H2 first configuration
I set up this model, I did access via com port, I am required username and password, I tried with user admin and passwword: blank password 1234 but I can not access. I also did a hard reset ...
- Dec 03, 2015
Hi marioalpha,
This is the link where I got the steps that I have summarized for you recently. However, let me share this old forum thread I found and it might help. Take note that some of the links on the old forum thread I have shared are not active anymore. Possible reason here might be that the FSM726 is an old model of a managed switch.
DaneA
NETGEAR Community Team
DaneA
Nov 22, 2015NETGEAR Employee Retired
Hi marioalpha,
Welcome to the community! :smileyhappy:
It seems that you might need to reset the CLI password. Here are the steps below to reset the password:
a. While booting up, press to enter boot code menu.
b. Press in boot code main menu to enter debug menu.
c. Press "5" to choose "Flash Access."
d. Press "2" to choose "Flash Erase."
e. "Start of sector #": Press 23 Enter.
f. "End of sector #": Press 31 Enter.
g. Confirm this command.
Hope it helps.
DaneA
- marioalphaDec 03, 2015Aspirant
when I Press "5" to choose "Flash Access" do not go into any menu :-(
- DaneADec 03, 2015NETGEAR Employee Retired
Hi marioalpha,
DaneA
thank you very much for the help was very helpful.
I can now configure ;-)
