Milkman00
Aug 06, 2017Aspirant
FSM7326P Not booting past U-Boot
Hi Everyone. I have a FSM7326P that will not boot past U-Boot. Something about magic number missing (firmware gone). I am starting the very long process of uploading the firmware via Serial cab...
Milkman00
Aug 07, 2017Aspirant
I did the file transferr, and it just sat there afterwards. I pressed Control Break and it said 0 bytes transferred, so obviously there is some sort of EOF sequence that I was supposed to hit, but didn't.
Anyone that can assist loading firmware through U-Boot would be aoorecuiated.
DaneA
Aug 08, 2017NETGEAR Employee Retired
Hi Milkman00,
Welcome to the community! :)
If ever you have not yet came across with the article below, kindly try the steps indicated.
What do I do when my FSM managed switch does not boot up?
DaneA
NETGEAR Community Team
- Milkman00Aug 08, 2017Aspirant
Unfortunately I cannot boot past U-Boot to get to the Utility menu referenced in this article.
I can get into U-Boot and it has an option (loadb) to upload firmware through there, I just need to know the steps to do that.
Thanks!
- DaneAAug 08, 2017NETGEAR Employee Retired
I suggest you to open a chat or online case with NETGEAR Support at anytime for further assistance. The NETGEAR Support Team might be able to provide you with further troubleshooting steps.
DaneA
I do not have a support contract, and was looking for some free assistance from the community. I am hoping someone can advise how to load firmware from uboot using the loadb command. I am sure I am not the first one that has tried to do this.
Thanks!
- DaneAAug 20, 2017NETGEAR Employee Retired
The switch can only be recovered if it loads the utility menu.
What is the serial number of your FSM7326P switch? Kindly send me a private message of the picture the shows the serial number labeled on your FSM7326P switch.
DaneA
- DaneAAug 24, 2017NETGEAR Employee Retired
I just want to follow-up on this. There are no available instructions on how to load the firmware using loadb command. As I have mentioned recently, the switch can only be recovered if it loads the utility menu. I just want to check if there is hardware warranty left to your FSM7326P switch via its serial number.
We’d greatly appreciate your feedback.
DaneA
