KimFord
Aug 09, 2016Aspirant
FVS318Gv2 in a strange state after Firmware 4.3.3-8 update attempt
Hi there, There are quite a few posts here about not being able to update the firmware on this device from 4.3.3-6 to 4.3.3-8 via the UI. In going through these, I noticed that many folks had...
AlexPe
Aug 09, 2016NETGEAR Expert
Hi KimFord,
Can you try the default username and password? Also you can try to factory reset a couple times, maybe that might free it from this condition.
Try doing the hold the reset in power on 30 secs, power off. Do this for 3 times then try the interface again.
If nothing then contact support to see if you can RMA the device through my.netgear.com.
AlexPe
