KimFord
Aug 09, 2016Aspirant
FVS318Gv2 in a strange state after Firmware 4.3.3-8 update attempt
Hi there, There are quite a few posts here about not being able to update the firmware on this device from 4.3.3-6 to 4.3.3-8 via the UI. In going through these, I noticed that many folks had...
AlexPe
Aug 09, 2016NETGEAR Expert
Hi KimFord,
Can you try the default username and password? Also you can try to factory reset a couple times, maybe that might free it from this condition.
Try doing the hold the reset in power on 30 secs, power off. Do this for 3 times then try the interface again.
If nothing then contact support to see if you can RMA the device through my.netgear.com.
AlexPe
KimFord
Aug 11, 2016Aspirant
Hi Alex,
Thanks for the advice... to make a long story short, i cycled the power and the device is now bricked regardless of how many times or how long I press the reset button.
Kim
