Raddo2003
Jan 21, 2017Aspirant
FVS336GV2 VLANS and VOIP traffic
Hi
We have recently aquired a M4300 52G and 3 M4300 28 Port switches.
They have been setup with a Auto Voip based vlans that include all the main ports and not the uplink ports on VLAN2. vlan 2 is then tagged on the uplink ports.
The issue occours when the units are rebooted. They loose the tagging from the uplink ports. As such the whole voice lan wont talk accross the switches.
Am I missing something obvious? I am saving the configs before rebooting!
I have copied the config below.
Thanks in advance!
vlan database
vlan 2
vlan routing 1 1
vlan routing 2 2
vlan association mac 14:58:D0:03:E3:14 2
exit
configure
stack
member 1 4
exit
slot 1/0 4
set slot power 1/0
no set slot disable 1/0
line console
exit
line telnet
exit
line ssh
exit
auto-voip vlan 2
auto-voip oui 00:08:5D oui-desc "Aastra"
auto-voip oui 08:00:0F oui-desc "Mitel"
interface 1/0/1
auto-voip oui-based
exit
interface 1/0/2
auto-voip oui-based
exit
interface 1/0/3
auto-voip oui-based
exit
interface 1/0/4
auto-voip oui-based
exit
interface 1/0/5
auto-voip oui-based
exit
interface 1/0/6
auto-voip oui-based
exit
interface 1/0/7
auto-voip oui-based
exit
interface 1/0/8
auto-voip oui-based
exit
interface 1/0/9
auto-voip oui-based
exit
interface 1/0/10
auto-voip oui-based
exit
interface 1/0/11
auto-voip oui-based
exit
interface 1/0/12
auto-voip oui-based
exit
interface 1/0/13
auto-voip oui-based
exit
interface 1/0/14
auto-voip oui-based
exit
interface 1/0/15
auto-voip oui-based
exit
interface 1/0/16
auto-voip oui-based
exit
interface 1/0/17
auto-voip oui-based
exit
interface 1/0/18
auto-voip oui-based
exit
interface 1/0/19
auto-voip oui-based
exit
interface 1/0/20
auto-voip oui-based
exit
interface 1/0/21
auto-voip oui-based
exit
interface 1/0/22
auto-voip oui-based
exit
interface 1/0/23
auto-voip oui-based
exit
interface 1/0/24
auto-voip oui-based
exit
interface 1/0/25
auto-voip oui-based
exit
interface 1/0/26
auto-voip oui-based
exit
interface 1/0/27
auto-voip oui-based
exit
interface 1/0/28
auto-voip oui-based
exit
interface 1/0/29
auto-voip oui-based
exit
interface 1/0/30
auto-voip oui-based
exit
interface 1/0/31
auto-voip oui-based
exit
interface 1/0/32
auto-voip oui-based
exit
interface 1/0/33
auto-voip oui-based
exit
interface 1/0/34
auto-voip oui-based
exit
interface 1/0/35
auto-voip oui-based
exit
interface 1/0/36
auto-voip oui-based
exit
interface 1/0/37
auto-voip oui-based
exit
interface 1/0/38
auto-voip oui-based
exit
interface 1/0/39
auto-voip oui-based
exit
interface 1/0/40
auto-voip oui-based
exit
interface 1/0/41
auto-voip oui-based
exit
interface 1/0/42
auto-voip oui-based
exit
interface 1/0/43
auto-voip oui-based
exit
interface 1/0/44
auto-voip oui-based
exit
interface 1/0/45
auto-voip oui-based
exit
interface 1/0/46
auto-voip oui-based
exit
interface 1/0/47
auto-voip oui-based
exit
interface 1/0/48
auto-voip oui-based
exit
interface 1/0/49
vlan participation include 2
vlan tagging 2
exit
interface 1/0/51
vlan tagging 2
exit
interface 1/0/52
vlan tagging 2
exit
interface vlan 1
routing
ip address 172.29.161.254 255.255.240.0
exit
interface vlan 2
routing
ip address 172.29.150.254 255.255.255.0
exit
ip management vlan 1 172.29.161.254 255.255.240.0
router rip
exit
router ospf
exit
ipv6 router ospf
exit
ip default-gateway 172.29.161.1
exit
Never mind
All the uplink ports must also be a member of the Auto-Voip config or the Tags are not updated on reboot.
1 Reply
- Raddo2003Aspirant
Never mind
