AllanA
Feb 28, 2020Guide
Generic 10G Wiring question
I have CAT 7 cable runs and am looking to create a 10GB backbone between our servers and key area's of our network where end-users will have 1GB throughput (until costs come down). I'm at the junctur...
AllanA
Mar 01, 2020Guide
Thank you. While it's logical, It seems odd to me to think there are advantages to not using the SFP+ modules. I'm glad I asked.
With the non-SFP+ switches, is every port then a 10G port or is it isolated to those ports dedicated to the higher speed? To control costs I'm looking to slowly meter out deployment of the 10G backbone and then extending it outward. I would imagine 12, 24 or 52 ports of 10G capability would be much more expensive than 2,4, or 6 dedicated 10G ports with the rest being 1G.
msi
Mar 01, 2020Luminary
In the case of the M4300 for all detail check the data sheets. There are switches in that product line that are majorly 10/100/1000 BASE-T (typically with the one model having PoE capability. These often have 2 SFP+ and 2 10GBASE-T ports. There are other models that are mostly 10G oriented where you have a selection of mixtures or only a certain type of ports being 10GBASE-T or SFP+.
There is a mixture of models available, if you want to control cost, consider the half-wide models with 8 or 16 10G ports, they are 10G only, but they are less expensive than the largest models such as a fully built-up M4300-96X (which even supports some QSFP+).
