Tim_Casey
Apr 30, 2018Initiate
GS105Ev2 FW reads v5.4.0.3
I was looking through the F/W versions of my various switches to make sure they are all current. My GS105Ev2 is reporting back in ProSAFE Plus Configuration Utility that is has F/W v5.4.0.3. The Ne...
- May 01, 2018
I went ahead and did the F/W upgrade with the latest .bin file, version 1.5.0.5 without any trouble.
I just found it curious that the readback F/W version was so far off (and ahead of) the most current version. I imagine it was coded with a typographical error.
All OK on my end. Thanks for your reply.
JohnC_V
May 01, 2018NETGEAR Employee Retired
Hi Tim_Casey,
Welcome to our community!
GS105Ev2 has the latest firmware version v1.5.0.5 and firmware v5.4.0.3 is invalid. May you be able to provide some screenshots so that we can have a better view of your issue?
- Tim_CaseyMay 01, 2018Initiate
- bitsecMay 07, 2018Aspirant
I also bought several GS105Ev2 switches, and they all have firmware V5.4.0.3. Screenshot from the ProSAFE Plus Configuration Utility is attched. I flashed them with the latest firmware V1.5.0.5 and were successful.
The part number, as stated in the box, is GS105E-2A1NAS.
There is no web configuration in the firmware V5.4.0.3. The built-in webserver replies 404 not found.
% curl -siv http://192.168.0.239
* About to connect() to 192.168.0.239 port 80 (#0)
* Trying 192.168.0.239... connected
* Connected to 192.168.0.239 (192.168.0.239) port 80 (#0)
> GET / HTTP/1.1
> User-Agent: curl/7.29.0
> Host: 192.168.0.239
> Accept: */*
< HTTP/1.1 404 Not found
< Connection: close
Connection: close<
* Closing connection #0
- schumakuMay 07, 2018Guru - Experienced User
XavierLL - that's one for you. Looks like a production/manufacturing firmware wasn't properly updated before shipping.
- XavierLLMay 07, 2018NETGEAR Employee Retired
Hi all,
Thanks schumaku for letting me know :)
bitsecAbout the GS105E-2A1NAS it´s a customer specific SKU that comes with a specific firmware configuration and it´s not available in our official retail or distribution channels.
When you buy GS105E please make sure that you buy the GS105E-200NAS so will come with the proper firmware .
Regards
Hope it helps!
Xavier Lleixa
NETGEAR CBU PLM
