HomebrewerD
Dec 15, 2010Aspirant
GS108E Firmware Upgrade Issues
Hi, I recently tried to upgrade to v1.00.06 firmware on a GS108E I had purchased. However, I have been having severe problems trying to upgrade it and I fear that the 'managed' half of this manage...
Nhellie
Apr 14, 2015Virtuoso
Did you try using the Prosafe plus configuration utility? Do you get the same issues as mentioned above? I use the latest version of the utility to update and did not have any issues.
David_Gray wrote: This continues to be a problem. Today I flashed the GS116Ev2 but even shutting down the Firewall on Windows 8.1 still didn't help. I installed Klever Pumpkin tftp and had to change the time-out on that to 60 seconds before it would successfully transfer. Once transferred everything worked like clockwork. NETGEAR: is this something that can be looked at either a) change it so it works or b) give clear instructions on how people can go about uploading it manually. I think this would benefit everyone.
