BurrtIceCream
Jul 31, 2016Aspirant
GS108Ev3 and Uverse NVG599 compatability
Anybody have experience with how to get this switch to see the internet? ATT says no switches behind the gateway are allowed. I just cannot believe that. I searched and searched and found some commen...
- Aug 04, 2016
Hi BurrtIceCream,
I am glad that you were able to figure it out and resolved the problem. :)
Since the problem has been sorted out, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
NETGEAR Community Team
daltont2000
Aug 03, 2016Aspirant
The "switch and manager ip address are not in the same subnet" message can be resolved as per Netgear manual in the following way:
Diagnostics and Troubleshooting
71
ProSAFE 8-Port and 16-Port Gigabit Click Switch
The Switch Information screen displays.
6.
Select
System > Monitoring > Cable T
ester
7.
Select one or more check boxes.
8.
Click the
T
est Selected Port
button.
The switch tests the cable connection for the selected port and displays the results.
Resolve a Subnet Conflict to Access the Switch
If you power on the switch before you connect it to a network that includes a DHCP server,
the switch uses its own default IP address of 192.168.0.239. This subnet might be different
from the subnet used in your network. You might see the following message if you try to use
the ProSAFE utility to access the switch:
The switch and manager IP address are not in the same subnet.
To fix this subnet conflict:
1.
Disconnect the Ethernet cable between the switch and your network.
2.
Unplug the switch’
s power cord.
3.
Reconnect the Ethernet cable between the switch and your network.
4.
Plug the switch’
s power cord into an electrical outlet.
The switch powers on. The network DCHP server discovers the switch and assigns it an
IP address that is in the correct subnet for the network."
- Apr 12, 2023Anonymous
