BurrtIceCream
Jul 31, 2016Aspirant
GS108Ev3 and Uverse NVG599 compatability
Anybody have experience with how to get this switch to see the internet? ATT says no switches behind the gateway are allowed. I just cannot believe that. I searched and searched and found some commen...
- Aug 04, 2016
Hi BurrtIceCream,
I am glad that you were able to figure it out and resolved the problem. :)
Since the problem has been sorted out, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
NETGEAR Community Team
BurrtIceCream
Aug 03, 2016Aspirant
Hello, I solved the issue. I feel really stupid. When I checked the IP address settings on the PC's net adapter I noticed they were static. For the life of me I do not remember changing that from allowing a DHCP server to provide them. Must be my oldmanitis kicking in. Should have been the first thing i checked.
Sorry to have wasted your time. The switch is working fine now!
DaneA
Aug 04, 2016NETGEAR Employee Retired
Hi BurrtIceCream,
Cheers,
DaneA
- Apr 12, 2023Anonymous
