jgraham2's avatar
jgraham2
Follower
Mar 31, 2020
GS108TV3 snmpget unknown user admin
I have setup the switch to use the web browser interface (GUI) from thelocal LAN connection only.
When I log in using firefox and username jgraham@traclabs.com and my password, the GUI says 'Welcome admin' in the upper right corner. This is fine.
From my ubuntu linux laptop, I can use the following command with good results:
`snmpget 10.0.0.123 -v3 -u admin -lnoAuthNoPriv -On IF-MIB::ifInOctets.1`
I get back the mib/oid info.
I am trying to set up an IDENTICAL netgear switch, but when I run the above command I get the error 'no such user' I assume for 'admin'.
How do I get 'admin' to be recognized from snmpget?
I looked through the entire GUI and the pdf manual and did some web searching but have not been able to figure it out.
1 Reply
  • michaelkenward's avatar
    michaelkenward
    You might get better and quicker replies, and find other answers, over in the appropriate section for your device:
    Switches - NETGEAR Communities
    No need to repost there, unless you want to – that will just clutter up the place with duplicated messages – but you might find advice related to your hardware.
    I have asked the Netgear moderator to move your message.
ProSupport for Business
