millhaus's avatar
millhaus
Initiate
Dec 02, 2023
GS110EMX uplink to XS505M only 5gbit
Hello everybody! 👋
Model: GS110EMX, Firmware: 1.0.2.7
My problem:
  • If I connect my 10G TB3 ethernet adapter (on the 2nd floor of our house) to the unmanaged X505M (in the basement, approx 20m Cat6 cable house wiring), I get a speed of about 9.7Gbit (measured with iperf3 both to a QNAP NAS and a NUC) -> fine 🎉
  • If I connect my 10G TB3 ethernet adapter to the GS110EMX, the port is in 10G Mode (both green LED flashing) -> fine 🎉
  • But if I connect the GS110EMX via Cat6a cable to the wall RJ45 socket which is connected to the XS505M, this uplink port is only in 5G Mode 🙄 (only one green LED flashing and according to the web gui tab 'port status'). Speed is set to 'Auto'.
I tried to change the speed setting of the uplink port from Auto to 10G, but the web interface only offers options up to 100M Full Duplex (why is that? 😕)
Anyone an idea why I get only 5G uplink? It can't be the house cabling, because I get almost full 10Gbit when plugging my 10g adapter directly into the walls' RJ45 socket 🤔
Is there a CLI interface to this switch (ssh or telnet console etc) to manually config port settings?
1 Reply
  • schumaku's avatar
    schumaku
    For copper link speeds starting from 1000Mb/s and up, auto negotiation is mandatory.
    Quickly looped-in an XS505M in the uplink to an XS728T on the almost two decades old in-house installation (yes, all CAT6A modules on some qualified 980 MHz cabling) - about 35 meters including patch cables - the XS505M does show two green LEDs on both ports. Here the GS110EMX with the port #10 looped through the XS505M on 2 meter patch cord:
ProSupport for Business
